jhantares
Filters: 272
Kaleidoscopic Transformer by jhantares
http://www.filterforge.com/filters/13299.html
jhantares
Filters: 272
How to use this filter
The source image is connected to a kaleidoscope component followed by Blend/Mask component. Up to 14 sliders alter the generated pattern by these components.
See following lines on how to alter patterns from connected sliders.
Component shortcuts
GRx -> Gradient components
SC -> Scale component
K1-K2 -> Kaleidoscope component
ND -> Noise Distortion component
BR -> Bricks component
HSL -> Hue component
Use "GR-Select" to select one of four masks. Alter masks by "GRx" sliders.
Check "Mosaic on" to use "BR" sliders.
Check "Distortion on" to use "ND" sliders.
Check "K2 on" to use "K2" sliders.
Check "Hue on" to use slider "HSL-Hue".
Although that seems that nobody seems to care to comment, I want to say that I like the kaleidoscope filters you make and is great, cool and useful, although the problem for me is that you can not judge and know if the filter is well done or not if the only image used is the lifesaver, and should be then tested with other real world images tp really see that awesome kaleidoscopic effects come to life
Thanks for making all these kaleidoscopic variations filters and is think they are worth it
jhantares
Filters: 272
Thanks a million for your kind comment.
