| Posted: September 23, 2015 6:20 am | ||||
Good, creative and artistic, I think that this can be good with the right settings and selected image source, will see how it works
Thanks |
| Posted: September 23, 2015 6:23 am | ||||
Nice. It also recalls me some famous carnival paintings.
| Posted: September 23, 2015 7:38 am | ||||
Thanks SpaceRay & Ramlyn. Sometimes the "tall triangles" give the images a sort of harlequin look.
| Posted: September 23, 2015 12:38 pm | ||||
DJI
I think this filter has a lot of potential,but those grainy lines are a real distraction for me. I'm just not sure why you put those in.
![]() "Art is quite useless." Oscar Wilde |
| Posted: September 24, 2015 12:40 am | ||||
I agree with you that the grainy lines are not always nice, I suposse you mean the lines on the edges of triangles, the good thing is that you can remove them easily: REMOVE UNWANTED DIAGONAL LINES - GROUT There are two ways 1 - Just go to Grout Color, click on it, and then go to A value and put it at 0, and so all the grout lines will be removed as shown here below on the screenshot 2 - Uncheck the Grout checkboxes you want so these lines are not shown, or leave only the ones you may like MODIFY TRANSPARENCY OF DIAGONAL LINES - GROUT you can also change how much transparency you want for these lines to be shown Go to Grout Color, click on it, and then go to A value and modify it as you want, 0 full transparency, 100 full solid |
| Posted: September 24, 2015 1:27 am | ||||
DJI
HA! That's what I get for making a snap judgement! Sometimes when I see something in a filter I don't like I just delete it without looking any further
| Posted: September 24, 2015 2:48 am | ||||
I understand not liking the lines. Here is a variation of the filter allowing the grout texture (perlin noise) to be turned off. And as mentioned before, grout can be turned completely off on each level or the alpha color reduced. If there is an interest in this variation, I will release it as an update.
Triangles Again noise option.ffxml Math meets art meets psychedelia. |
| Posted: September 24, 2015 12:07 pm | ||||
DJI
Thanx man.
| Posted: September 24, 2015 12:21 pm | ||||
Also I believe the original intent of FF was to have filters with 10 controls or less. I broke the rule with 14...
Nice example Ray Math meets art meets psychedelia. |
| Posted: September 24, 2015 1:01 pm | ||||
Good that you have added an option to remove the noise in the grout, because the lines grout are nice and good, but not the noise they had
Will see what you have done |
| Posted: September 25, 2015 3:28 pm | ||||
| Posted: September 28, 2015 12:58 pm | ||||
thanks very much for upgrading it and add the grout texture switch, so you can choose if you want it or not, good, as the lines grout plain are nice and good idea
| Posted: September 30, 2015 1:29 am | ||||
Although I like very much this one and is well done, i wonder if there could be a way to make another filter similar to this one that would ONLY have triangles without making rombhus triangles, I mean that the triangles are always triangles, and can not be joined two of them with the same color
Something like this example but using the souce image color instead. This example is ONLY to show that the rhombus are made with two different colored triangles, and I do not mean that I want to have the same pattern, and is not what I want suggest Also the triangles can be done either vertically as shown on the example or horizontally |
| Posted: October 2, 2015 11:39 pm | ||||
The "matched" colors on the triangles was originally an accident which I stayed with ( for the tall triangles only, contributes to the "harlequin" look). I will look at possible changes to change the method used to color all of the triangles, both the wide and tall triangles. I'll post those changes here if I come up with something.
| Posted: October 3, 2015 8:07 pm | ||||
Thanks for explaining it how you made it, and this is usually what many times happen, that you are experimenting with components and by accident you get something cool and nice and then want to continue to improve it until making a good filter of it as you have done very well
Of course that the above is just a suggestion, and not that you have to do it, is just an idea, and do not know if making the triangles all different could be hard to achieve or not |
| Posted: October 6, 2015 10:57 pm | ||||
It made me look at the filter in a different way. Probably won't do the variation you suggested, a lot of components would need to be added to do it. Ideas are always good, though!
| Posted: October 6, 2015 11:02 pm | ||||
