jhantares
Filters: 272
Looping NIK Generator-23 by jhantares
http://www.filterforge.com/filters/13278.html
jhantares
Filters: 272
Looping N)ew I)mage K)aleidoscope 23.
Your image can be transformed by 5 generators. A repeated rotation and shift operation is used on different slices of the image. See following lines on how to use this filter.
Component shortcuts
TW1-5 -> 5 generator components
BI -> Bricks component
TI -> Tiles component
K1 -> Kaleidoscope component
BG -> Background color/noise
Set "Select Twister" to 1
Use sliders: "TW1". Check "Bricks on" to use "BI" sliders.
Set "Select Twister" to 2
Use sliders: "TW2", "TI", "Iterations"
Set "Select Twister" to 3
Use sliders: "TW3", "Scale image 3-5", "Iterations"
Set "Select Twister" to 4
Use sliders: "TW4", "Scale image 3-5", "Iterations"
Set "Select Generator" to 5
Use sliders: "TW5", "Scale image 3-5", "Iterations"
Check "K1 on" to use "K1" sliders.
Check "Background on" to use "BG" sliders.
18 unregistered users.
