jhantares
Filters: 272
MosPat Generator 18 by jhantares
http://www.filterforge.com/filters/13213.html
jhantares
Filters: 272
How to use this filter
This filter generates patterns using 3 different pattern sources. You can alter gradient and pattern by using assigned sliders. See following lines on how to use sliders.
Component shortcuts
GR-GR3 -> Color/Gradient controls
RO1 -> Rotate component
PA -> Pavement component
SC -> Scale component
M1 -> Script component
K1,K2 -> Kaleidoscope component
Set "Gradient Selector" to 1
Use sliders: "GR1", "GR3"
Set "Gradient Selector" to 2
Fixed "Spectrum" component is used.
Set "Gradient Selector" to 3
Use sliders: "GR1", "GR2", "GR3"
All gradients are altered by sliders "RO1". Uncheck "Pavement/Kal on" to use gradient pattern as is.
Check "Pavement/Kal on" and uncheck "Kal1 on" to use sliders "PA".
Check "Pavement/Kal on" and check "Kal1 on" to use sliders "PA" and "K1".
All patterns can be altered by "M1", "SC" and "K2" sliders.
12 unregistered users.
