jhantares
Filters: 272
NIK Generator 12 by jhantares
http://www.filterforge.com/filters/13212.html
jhantares
Filters: 272
How to use this filter
The source image is transformed thru two rotate, kaleidoscope and offset components. Up to 10 sliders alter the source image by these components. 5 different generators alter the resulting image.
See following lines on how to alter these patterns from connected sliders.
Component shortcuts
RO1-RO3 -> Rotation component
K1-K5 -> Kaleidoscope component
BR -> Bricks component
OF1-OF2 -> Offset component
HSL -> Hue component
ST -> Scale component
BG -> Background Color component
G2-G5 -> Gradient components
FR1-FR4 -> Free Rectangle component
Set "Pattern selector" to 1
Use following sliders to alter pattern: "RO1", "K1", "OF2", "RO2"
Set "Pattern selector" to 2
Use following sliders to alter pattern: "RO1", "K1", "OF2", "RO2", "FR1"
Set "Pattern selector" to 3
Use following sliders to alter pattern: "K4","BR", "FR2", "GR3"
Set "Pattern selector" to 4
Use following sliders to alter pattern: "K1", "RO1", "FR3", "Iterations 1"
Set "Pattern selector" to 5
Use following sliders to alter pattern: "RO1", "K1", "OF2", "FR4", "RO3", "OF1", "K5", "Iterations 2"
Check "Kaleidoscope on" to use kaleidoscope "K2" near "result" component.
Check "HSL on" to use hue, saturation and lightness component near "result" component.
Check "Background Noise on" to use "BG" controls for background pattern.
12 unregistered users.
