jhantares
Filters: 272
Looping NIK Generator 17 by jhantares
http://www.filterforge.com/filters/13211.html
jhantares
Filters: 272
How to use this filter
Component shortcuts
RO1,RO2 -> Rotate component
FR -> Free Rectangle component
K1,K2 -> Kaleidoscope component
Iterations 1 -> set how often pattern transformation is repeated
Flip X, Flip Y -> Flip component
Rotate image by sliders "RO1-" and alter image by kaleidoscope component altered by "K2". A "Free Rectangle" component cut a slice out of the image, use sliders "FR" to alter slice form.
Slider "Iterations 1" alter slice repeating, slider "RO2-" alter rotation of repeated slices. Check "Flip on" to use "Flip X and/or Flip Y" checkboxes.
Check "Kaleidoscope on" to use kaleidoscope "K1" right in front of "result" component. Kaleidoscope "K1" can be altered by sliders "K1". Check "Show Slice" to see slice cut out.
You get interesting new patterns by using the looping components. Just play with all sliders or use presets.
