DJI
Official Bologna Tester
Filters: 257
Camera UV Bump by xirja
http://www.filterforge.com/filters/13194.html
DJI
Filters: 257
Very interesting. smile:) I'm afraid you forgot to hook up the color controls. smile:(
Could you explain what this portion is doing?
xirja
Idididoll Forcabbage
As a snippet it was intended for those who want to tinker a bit, so color controls was clutter imho. The main thing was to demonstrably unify perspective movement and uv mapping, shading, etc.
I think that was for ensuring a continuous transition at all angles. Certain heights or pitches caused a glitch in the gradient. The height needs to be readjusted at the upper range, but I'm finished for now trying to fix all the numbers. This is definitely a WIP snippet.
This is something that could have been posted in the forum to be worked on, but having had only 5 filters published, well you know...
xirja
I'm particularly pleased with the ability to sit down in the terrain, but it does need some polishing as seen on the tops and the uneven bending in the elevation gradient:
xirja
Swap the image in for the checker and change the repeat on the gradients to 1:
xirja
...and our lovely lionfish comes alive...
DJI
Filters: 257
Sorry for asking a side question but i've been wanting to ask it for a while. How do you take a screenshot of the filter editor? smile:?:
OOOO I know... smile:D
I don't know what system you are running DJI but in osx there are key combos to press for screenshots....OSK KEY COMBOS
Then in windows I use MWsnap which I have used for quite some time..Its free and very small in size....MWSNAP
DJI
Filters: 257
Hey! Thanx CFandM. smile:D I had to read a MS blog about it. You have to paste it in MS Paint.(Something that simple and I never knew that.) smile:| smile:?: smile:D
DJI you can also use the snipping tool in Windows (should come with the OS, at least Windows 7), and save an image directly (no need to paste in MSPaint).
Oh no! Not much of a "lifesaver" is it now...
Thanks a million, no a Graham's number, Xirja! smile8)
DJI
Filters: 257
Thanx Indigo Ray! Found the tool and your right,it works great. I've had windows 7 for about 2 years and I still haven't bothered looking over the fine points to see what the program does. smile:(
xirja
Mostly to you sire smile:)
https://www.filterforge.com/filters/10844.html
https://www.filterforge.com/forum/read...&TID=11079
This snippet is WOW and TY for sharing smile:)
