| jhantares | ||
| Posted: July 22, 2015 9:00 am | ||
| jhantares |
How to use this filter
Component shortcuts PA -> Pavement component RO1,RO2 -> Rotate component FR -> Free Rectangle component K1 -> Kaleidoscope component Iterations 1 -> set how often pattern transformation is repeated Flip X, Flip Y -> Flip component Overlay a pavement pattern by sliders "PA", rotate image by sliders "RO1-". A "Free Rectangle" component cut a slice out of the image, use slider "FR" to alter slice form. Slider "Iterations 1" alter slice repeating, slider "RO2-" alter rotation of repeated slices. Check "Flip on" to use "Flip X and/or Flip Y" checkboxes. Check "Kaleidoscope on" to use kaleidoscope "K1" right in front of "result" component. Kaleidoscope "K1" can be altered by sliders "K1". Check "Show Slice" to see slice cut out. You get interesting new patterns by using the looping components. Just play with all sliders or use presets. |
Interesting filter JHantares !
visit https://gisoft.ca |
| Posted: July 22, 2015 4:23 pm | ||
12 unregistered users.
