jhantares
Filters: 272
MosPat Generator 15 by jhantares
http://www.filterforge.com/filters/13189.html
jhantares
Filters: 272
How to use this filter
This filter generates patterns using 2 different pattern sources. You can alter gradient and pattern by using assigned sliders. See following lines on how to use sliders.
Component shortcuts
GR1,GR2,GR12 -> Color/Gradient controls
BG -> Background Color Chaffs component
RO1,RO2 -> Rotate component
K1,K2 -> Kaleidoscope component
TI -> Tiles component
Check "Select Gradient"
Use slider "GR1"
Uncheck "Select Gradient"
Use sliders "GR2"
Use following sliders to alter pattern: "GR12", "RO1", "TI", "K2", "K1", "RO2"
Check "Background on" to use slider "BG".
