jhantares
Filters: 272
KalPat Generator 4 by jhantares
http://www.filterforge.com/filters/13187.html
jhantares
Filters: 272
How to use this filter
This filter transforms your image using 4 different sources. You can alter the patterns by using assigned sliders. See following lines on how to alter these patterns.
Component shortcuts
GRxxx -> Gradient/Pattern control
K3 -> Kaleidoscope component
Set "Pattern Selector" to 1
Use following sliders to alter pattern: "GR1", "GR12", "GR1234"
Set "Pattern Selector" to 2
Use following sliders to alter pattern: "GR2", "GR12", "GR1234"
Set "Pattern Selector" to 3
Use following sliders to alter pattern: "GR3", "GR1234"
Set "Pattern Selector" to 4
Use following sliders to alter pattern: "GR4", "GR1234"
Check "K3 on" to use kaleidoscope component altered by sliders "K3".
26 unregistered users.
