DJI
Official Bologna Tester
Filters: 257
Multi-res Triangles by Skybase
http://www.filterforge.com/filters/13160.html
DJI
Filters: 257
Now this one really looks interesting. smile:D
Thannks~
In general here are a couple clues:
1. It doesn't offer many options because it's relatively simple.
2. You can change the size via the size slider.
3. The current edit is slightly biased in terms of numbers to give the best results with the threshold feed. You can, however, adjust the filter so the output result has more of smaller triangles or larger triangles. You can alternatively try different patterns to use as masks.
Here's another potential idea.
11 unregistered users.
