jhantares
Filters: 272
Looping NIK Generator 14 by jhantares
http://www.filterforge.com/filters/13139.html
jhantares
Filters: 272
How to use this filter
Component shortcuts
RO1,RO2 -> Rotate component
Scale Start/End -> Free Rectangle component
K1 -> Kaleidoscope component
Iterations 1 -> set how often pattern transformation is repeated
Flip X, Flip Y -> Flip component
Rotate image by sliders "RO1-". A "Free Rectangle" component cut a slice out of the image, use "sliders "Scale Start Y/End Y" to alter slice size.
Slider "Iterations 1" alter slice repeating, slider "RO2-" alter rotation of repeated slices. Check "Flip on" to use "Flip X and/or Flip Y" checkboxes
Check "Kaleidoscope on" to use kaleidoscope "K1" right in front of "result" component. Kaleidoscope "K1" can be altered by sliders "K1".
Check "Show Slice" to see slice cut out.
You get interesting new patterns by using the looping components. Just play with all sliders or use presets.
12 unregistered users.
