DJI
3D Reflective Webs Photo Effect by DJI
http://www.filterforge.com/filters/13128.html ![]() "Art is quite useless." Oscar Wilde |
| Posted: June 23, 2015 6:46 am | ||||
DJI
DJI
| Posted: June 23, 2015 6:47 am | ||||
DJI
| Posted: June 23, 2015 6:48 am | ||||
DJI
DJI
| Posted: June 23, 2015 6:49 am | ||||
DJI
DJI
So there ya go. Have fun.
| Posted: June 23, 2015 6:50 am | ||||
This filter is WOW ! And it can be use with all images or photos. Lot of possibility my friend and your examples are so nice.
It gives me the idea to use it with an alpha bg for the final and apply this "final"on another image. Awesome filter DJI ! visit https://gisoft.ca |
| Posted: June 23, 2015 11:22 am | ||||
Oh that is wild! great stuff
| Posted: June 23, 2015 12:26 pm | ||||
DJI
Thank you both very much for your comments.
| Posted: June 23, 2015 4:33 pm | ||||
WOW!! Lovely and excellent! Great web texture that you can custom colorise with any source image colors. Well done
Also thanks for the nice and good examples made by you, as seems that nobody else is putting any examples after submitting a filter POSSIBLE SUGGESTION It comes to my mind now a possible suggestion that is only an idea, and is if possible to add an optional drop shadow in the back using alpha background transparent, you can of course do it as you want, and it can be done possibly in an alternative version of the filter if you want. so you can render then render the first web one with drop shadow and save it separate, then render another one and save it too, then load both of them on Photoshop or similar to layer them, one behind the other, so you can see the second one through the web holes of the first one. Also could be possible to render a third one to put behind the second one MULTI FILTER Another possible alternative is to be able to make another filter that could be able to do this as explained above ALL inside Filter forge and in one time, without having to render them separately. But do not know if this would make the filter slower, or could maybe there any possible problem. |
| Posted: June 24, 2015 5:46 am | ||||
Congratulations DJI! Very good filter.
| Posted: June 24, 2015 12:18 pm | ||||
DJI
Thanx Ramlyn!
| Posted: June 24, 2015 2:16 pm | ||||
It kinda requires a bit of restructuring. The thing right now is that it's effectively a filter that utilizes the height parameter to crank the shadows or the appearance of thickness. Although ultimately this has severe limitations due to the way FilterForge handles height, global illumination, etc. You can of course really push it with the lighting tab, you can add point lights to your scene of course to emphasize shadow and highlight but this doesn't really give control to you. This also relies on your height map, which in this filter, needs a helping hand. One of the precautionary things to remember is that the height map input is strictly grayscale, in other words, color input would be converted to grayscale. It's generally "ok" to input plain color since FilterForge is smart about that, but on the down side since it gets converted from one color space to another through some algorithm, you do lack control over the height parameter. This often results in undesirable artifacts or difficulties controlling the filter when you want to do a bit more later. So that was a bit of technical stuff for everybody. As for fun, I've went in and just modified the filter to some degree to what SpaceRay was talking about. I'll just... upload the mod sometime soon here. In general, I'm trying to keep the original core structure to the best of my ability while trying to construct SpaceRay features lol. So with respect! |
| Posted: June 24, 2015 9:06 pm | ||||
DJI
That's really good Skybase.
| Posted: June 25, 2015 12:25 am | ||||
I love this filter much although I have not had time to use it, but love much the organic web it can make
Is there any news for the shadow as skybase has shown very well? thanks |
| Posted: February 10, 2016 2:43 am | ||||
13 unregistered users.
