jhantares
Filters: 272
NIK Generator 24 by jhantares
http://www.filterforge.com/filters/13098.html
jhantares
Filters: 272
How to use this filter
Generates interesting kaleidoscopes by using the source image or four different gradient generators. See following lines on how to use sliders.
Component shortcuts
Gnnn -> Gradient components
K1,K2 -> Kaleidoscope component
ND2,ND3 -> Noise Distortion component
BR -> Bricks component
HSL -> Hue,Saturation,Lightness component
Set "Select pattern" to 1
Use source image as is.
Set "Select pattern" to 2
Use sliders to alter gradient pattern: "GR25", "GR2345"
Set "Select pattern" to 3
Use sliders to alter gradient pattern: "GR345", "G3"
Set "Select pattern" to 4
Set "Select pattern" to 5
Use sliders to alter gradient pattern: "GR2345", "G5"
Uncheck "Switch Grd/Col" to use "GR2345-Color 1" and check "Switch Grd/Col" to use gradient "GR2345"
Check "Bricks on" to use"BR" and "ND3" sliders.
Check "Distortion on" to use "ND2" slider.
Check "Kal12 on" to use "K1" and "K2" sliders.
Check "HSL on" to use "HSL" sliders.
17 unregistered users.
