jhantares
Filters: 272
Looping NIK Generator 13 by jhantares
http://www.filterforge.com/filters/13077.html
jhantares
Filters: 272
How to use this filter
Component shortcuts
RO -> Rotate component
OF -> Offset component
K1 -> Kaleidoscope component
FR -> Free rectangle component
Slice Rotation -> Rotation component
Iterations 1 -> set how often pattern transformation is repeated
Flip X, Flip Y -> Flip component
Shift source image by sliders "OF-" and rotate by "RO-". A "Free Rectangle" component cut a slice out of the image, use "sliders "FR-" to alter slice size.
Slider "Iterations 1" alter slice repeating, slider "Slice Rotation" alter rotation of repeated slices. Check "Flip on" to use "Flip X and/or Flip Y" checkboxes
Check "Kaleidoscope on" to use kaleidoscope "K1" right in front of "result" component. Kaleidoscope "K1" can be altered by sliders "K1".
Check "Show Slice" to see slice cut out.
You get interesting new patterns by using the looping components. Just play with all sliders or use presets.
17 unregistered users.
