jhantares
Filters: 272
MosPat Generator 12 by jhantares
http://www.filterforge.com/filters/13078.html
jhantares
Filters: 272
How to use this filter
This filter generates patterns using 4 different pattern sources. You can alter gradient and pattern by using assigned sliders. See following lines on how to use sliders.
Component shortcuts
GR1 -> Color/Gradient controls
TR -> Transition selector
OF -> Offset component
PO -> Polygon component
RO1,RO2 -> Rotate component
K1,K2,K3 -> Kaleidoscope component
HSL -> Hue,Saturation,Lightness component
Use sliders "GR1" - "GR3" to generate pattern.
Select Transition mode by selector "TR-Selector" and set kaleidoscope mode by slider "K3".
Uncheck "Kal1 on"
Use generated pattern
Check "Kal1 on"
Use following additionally sliders: "RO2", "PO", "K1", "HSL"
All patterns can be altered by "OF", "K2" sliders.
