jhantares
Filters: 272
MosPat Generator 20 by jhantares
http://www.filterforge.com/filters/13044.html
jhantares
Filters: 272
How to use this filter
This filter generates patterns using 3 different pattern sources. You can alter gradient and pattern by using assigned sliders. See following lines on how to use sliders.
Component shortcuts
GR1-GR4 -> Color/Gradient controls
RO1 -> Rotate component
NO -> Noise Distortion component
SC -> Scale component
TI -> Tiles component
K1,K2,K3 -> Kaleidoscope component
PA -> Pavement component
Set "Gradient Selector" to 1, 2
Use sliders: "GR1", "GR2"
Set "Gradient Selector" to 3
Use slider: "GR1", "GR3"
Use sliders: "GR1", "GR4"
All gradients are altered by sliders "NO", "RO1" and "K3". Uncheck "Pavement/Kal on" to use gradient pattern as is.
Check "Pavement/Kal on" and uncheck "Kal1 on" to use sliders "TI".
Check "Pavement/Kal on" and check "Kal1 on" to use sliders "TI", "PA" and "K1".
Check "Kal2 on" to use "K2" sliders.
17 unregistered users.
