jhantares
Filters: 272
MosPat Generator 11 by jhantares
http://www.filterforge.com/filters/13030.html
jhantares
Filters: 272
How to use this filter
This filter generates patterns using 2 different pattern sources. You can alter gradient and pattern by using assigned sliders. See following lines on how to use sliders.
Component shortcuts
GR1 -> Color/Gradient controls
TR-TR4 -> Transition controls
M1 -> Script component
PO -> Polygon component
RO1,RO2 -> Rotate component
K1,K2 -> Kaleidoscope component
Use sliders "GR1", "TR"-"TR4", "RO1" to generate pattern.
Select Transition mode by selector "TR-Selector".
Uncheck "Kal1 on"
Use generated pattern
Check "Kal1 on"
Use following additionally sliders: "RO2", "PO", "K1"
All patterns can be altered by "M1", "OF", "K2" sliders.
15 unregistered users.
