McGyver
What is a user title?
Filters: 10
McGyver
Filters: 10
I'm not sure if there is a problem downloading this filter or if some element of the filter was lost somehow, but this only loads as a grey patch of textile (the foreground texture?)... upon examining the filter in the editor, there seems to be less components than necessary to create the effect... I didn't really examine it too much, but it does seem broken somehow.
I just thought someone would want to know.
Too bad, it looked kinda useful.
Mardar
Graphics Junkie
Filters: 61
I just tested this filter and it works just fine. McGyver did you open it with no patterned background? This must have an image as the background to make the pattern work. If you opened it over a solid color or over an invisible background all you'll see is the texture. Hope this helps.
Edited:
Ooops It is just the invisible background that makes it a grey texture. My bad. smile:blush:
36 unregistered users.
