jhantares
Filters: 272
MosPat Generator 6 by jhantares
http://www.filterforge.com/filters/12926.html
jhantares
Filters: 272
How to use this filter
This filter generates patterns using 4 different gradient and/or pattern sources. You can alter the gradient/patterns by using assigned sliders. See following lines on how to use sliders.
Component shortcuts
GR1-3 -> Color/Gradient controls
TE -> Techno component
ST -> Stone component
RO -> Rotation component
K1,K2 -> Kaleidoscope component
Set "Select Gradient" to 1
Use following sliders to alter gradient: "GR1"
Set "Select Gradient" to 2
Use following sliders to alter gradient: "GR1", "GR23", "GR2"
Set "Select Gradient" to 3
Use following sliders to alter gradient: "GR23", "GR3"
Set "Select Gradient" to 4
Use following sliders to alter gradient: "GR23", "GR2", "TE"
Set "Pattern Selector" to 1
Use following sliders to alter pattern: "ST", "K1"
Set "Pattern Selector" to 2
Use following sliders to alter pattern: "ST", "K2"
Set "Pattern Selector" to 3
Use following sliders to alter pattern: "ST", "K1", "K2"
Set "Pattern Selector" to 4
Use following sliders to alter pattern: "ST", "K1", "K2", "RO"
23 unregistered users.
