jhantares
Filters: 272
Looping NIK Generator 8 by jhantares
http://www.filterforge.com/filters/12924.html
jhantares
Filters: 272
How to use this filter
Component shortcuts
FR -> Free Rectangle component
RO -> Rotate component
K1 -> Kaleidoscope component
OF -> Offset component
Slice Rotation -> Rotation component
Iterations 1 -> set how often pattern transformation is repeated
Rotate source image by sliders "RO-". Two "Free Rectangle" components cut a slice out of the image. Sliders "FR-" alter slice size. Slider "Iterations 1" alter slice repeating and slider "Slice Rotation" alter rotation of the repeated slices.
Check "Kaleidoscope on" to use kaleidoscope "K1" right in front of "result" component. Kaleidoscope "K1" can be altered by sliders "K1".
Check "Show Slice" to see slice cut out.
You get interesting new patterns by using the looping components. Just play with all sliders or use presets.
34 unregistered users.
