jhantares
Filters: 272
MosPat Generator 9 by jhantares
http://www.filterforge.com/filters/12909.html
jhantares
Filters: 272
How to use this filter
This filter generates patterns using 3 different pattern sources. You can alter gradient and pattern by using assigned sliders. See following lines on how to use sliders.
Component shortcuts
GR1,GR2 -> Color/Gradient controls
M1 -> Script component
SC -> Scale component
RO1 -> Rotate component
K1,K2 -> Kaleidoscope component
PA -> Pavement component
Set "Gradient Selector" to 1
Use these sliders to alter gradient: "GR1"
Set "Gradient Selector" to 2
Uses fixed "Spectrum" gradient
Set "Gradient Selector" to 3
Use these sliders to alter result: "GR1", "GR2"
All gradients can be altered by "RO1" slider. Uncheck "Pavement/Kal on" to use gradient as is.
Check "Pavement/Kal on" and uncheck "Kal1 on" to use "PA" sliders.
Check "Pavement/Kal on" and check "Kal1 on" to use "PA" and "K1" sliders.
All paterns can be altered by these sliders: "M1", "SC", "K2"
Casual Pixels
Dilettante
I like this filter a lot; great work.
There are tons of good tiling Texture filters, but this one really stands out.
jhantares
Filters: 272
jhantares
Filters: 272
Upd ate 1, new generator - How to use this filter
This filter generates patterns using 4 different pattern sources. You can alter gradient and pattern by using assigned sliders. See following lines on how to use sliders.
Component shortcuts
GR1,GR2,GR4 -> Color/Gradient controls
RO1,RO2 -> Rotate component
Use these sliders to alter result: "GR1", "GR3"
Se t "Gradient Selector" to 4
Use these sliders to alter result: "GR1", "GR4"
All patterns can be altered by these sliders: "M1", "SC", "K2"
34 unregistered users.
