jhantares
Filters: 272
Looping NIK Generator 7 by jhantares
http://www.filterforge.com/filters/12894.html
jhantares
Filters: 272
How to use this filter
Component shortcuts
OF -> Offset component
RO -> Rotate component
Size X, Size Y -> Free Rectangle component
K1 -> Kaleidoscope component
Shrink Scale -> Scale component
Slice Rotation -> Rotation component
Iterations 1 -> set how often pattern transformation is repeated
Shift source image by sliders "OF-Shift X", "OF-Shift Y" and rotate by "RO" silder. Two "Free Rectangle" components cut a slice out of the image. Sliders "Size X", "Slice Y" alter the slice. Slider "Iterations 1" alter slice repeating and sliders "Shrink Scale" and "Slice Rotation" alter scale and/or rotation of the repeated slices.
Check "Kaleidoscope on" to use kaleidoscope "K1" right in front of "result" component. Kaleidoscope "K1" can be altered by sliders "K1". Check "Show Slice" to see slice cut out.
You get interesting new patterns by using the looping components. Just play with all sliders or use presets.
32 unregistered users.
