jhantares
Filters: 272
KalPat Generator 1 by jhantares
http://www.filterforge.com/filters/12874.html
jhantares
Filters: 272
How to use this filter
This filter generates kaleidoscopic patterns using 7 different sources. You can alter the patterns by using assigned sliders.
See following lines on how to alter these patterns.
Component shortcuts
CO1, CO2,CO12 -> Color control
BR -> Bricks component
NRO -> Nose, Rotate, Offset component
K1,K2 -> Kaleidoscope component
PA -> Pavement component
HSL -> Hue, Saturation, Lightness component
Uncheck "Gradient Selector" to use "CO1" and "CO12" sliders. Check "Gradient Selector" to use "Co2" and "CO12" sliders.
Set "Selector" to 1
Use following sliders to alter pattern: "BR", "CO1", "CO2", "CO12"
Set "Selector" to 2
Use following sliders to alter pattern: "BR", "CO1", "CO2", "CO12", "NRO-Angle", "NRO-Scale"
Set "Selector" to 3, 4
Use following sliders to alter pattern: "BR", "CO1", "CO2", "CO12", "NRO-Offset X", "NRO-Offset Y"
Set "Selector" to 5
Use following sliders to alter pattern: "BR", "CO1", "CO2", "CO12", "NRO-Offset X", "NRO-Offset Y", "K2"
Set "Selector" to 6, 7
Use following sliders to alter pattern: "BR", "CO1", "CO2", "CO12", "PA"
All patterns can be altered by "K1" and "HSL" sliders. Have fun to explore the capabilities of this filter!
