jhantares
Filters: 272
Looping NIK Generator 4 by jhantares
http://www.filterforge.com/filters/12839.html
jhantares
Filters: 272
How to use this filter
Component shortcuts
K1 -> Kaleidoscope component
Angle -> Rotate component
Iterations 1 -> set how often pattern transformation is repeated
Shift source image by sliders "OF-Shift X", "OF-Shift Y". A "Free Rectangle" component cut a slice out of the image. Slider "Iterations 1" alter slice repeating and slider "Angle" alter rotation of the repeated slices.
Check "Kaleidoscope on" to use kaleidoscope "K1" right in front of "result" component. Kaleidoscope "K1" can be altered by sliders "K1". Check "Show Slice" to see slice cut out.
You get interesting new patterns by using the looping components. Just play with all sliders or use presets.
You'll love it, I hope so.
More of this type of filters coming soon...
33 unregistered users.
