jhantares
Filters: 272
Looping NIK Generator 3 by jhantares
http://www.filterforge.com/filters/12816.html
jhantares
Filters: 272
How to use this filter
Component shortcuts
K1 -> Kaleidoscope component
Shift Souce X / Y -> Offset component
Rotate Source -> Rotate component
EL -> Free Ellipse component
OF-Shift X / Y -> 2. Offset component
Rotation Output -> Rotation component
Iterations 1 / 2 -> set how often pattern transformation is repeated
Shift and/or rotate the source image by sliders "Shift Source X", "Shift source Y" and/or "Rotate Source". A "Free Ellipse" component cut a slice out of the image. You can alter the size of this slice by slider "EL-Slize size". Slider "Iterations 1" alter slice repeating and sliders "El-Shift X" and/or "EL-Shift Y" and/or "OF-Shift X", "OF-Shift Y" alter X/Y direction of the repeated slices.
A second loop component "Iterations 2" and "Rotation Output" rotates the resulting image of loop 1. You can alter the angle by "Rotation Output" and the count by "Iterations 2".
Check "Kaleidoscope on" to use kaleidoscope "K1" right in front of "result" component. Kaleidoscope "K1" can be altered by sliders "K1". Check "Show Slice" to see slice cut out.
You get interesting new patterns by using the looping components. Just play with all sliders or use presets.
You'll love it, I hope so.
More of this type of filters coming soon...
16 unregistered users.
