jhantares
Filters: 272
Looping NIK Generator 2 by jhantares
http://www.filterforge.com/filters/12815.html
jhantares
Filters: 272
How to use this filter
Component shortcuts
K1 -> Kaleidoscope component
Shift Souce X / Y -> Offset component
Slice size -> Free Rectangle component
Shift X / Y -> 2. Offset component
Rotation -> Rotation component
Iterations 1 / 2 -> set how often pattern transformation is repeated
Shift the source image by sliders "Shift Source X" and/or "Shift source Y". A "Free Rectangle" component cuts a tiles out of the image. You can alter the size of this slice by slider "Slize size". Slider "Iterations 1" alter slice repeating and sliders "Shift X" and/or "Shift Y" alter X/Y direction of the repeated slices.
A second loop component "Iterations 2" and "Rotation" rotates the resulting image of loop 1. You can alter the angle by "Rotation" and the count by "Iterations 2".
Check "Kaleidoscope on" to use kaleidoscope "K1" right in front of "result" component. Kaleidoscope "K1" can be altered by sliders "K1". Check "Show Slice" to see slice cut out.
You get interesting new patterns by using the looping components. Just play with all sliders or use presets.
You'll love it, I hope so.
More of this type of filters coming soon...
35 unregistered users.
