Used Frames by CFandM
http://www.filterforge.com/filters/1793.html
This version works best with square images.
yup, this is a good filter. you can see CF's thread on this one in the user gallery. i've been playing around with this one and find it quite good.
i did a little update on this, CF. i think it's a brilliant frame filter; it just needed an update smile:) i removed the offsets and replaced the cells with a perlin. i also added the v2 stuff of ambient occlusion and such. i also allowed for the removal of the black center with a transparency. i could have done it the life saver showing also and for anyone that wants it that way, simply remove the 'image' component nearest the results component and it'll flip to the life preserver.
i dont know how the name on this one got changed to 'frame depth', CF, but oh well smile:)
i hope this comes through right.
Frame Depth 1a (from Used Frames) by CF&M rev 1b.ffxml
Weird on that name changing but.....It did come through and Cool look on that one Craig.. smile:)
Might think about updating some of the others myself when I get the chance now that ThreeDee posted that script... smile:)
thanks, but i changed very little. it's mostly yours and quite brilliant.
You can blame my days as a picture framer.. smile:D smile:)
aha! so that's the secret! smile:)
shhh..Don't say that to loud.. smile;) smile:)
sorry Cf hadn't noticed this one before and it's actual a bit of a gem, great pattern in the frame smile:)
Thanks Carl... smile:)
I have several based on this method used.. smile:)
