jhantares
Filters: 272
jhantares
Filters: 272
How to use this filter
The source image is connected to a Switch, Pavement, Elevation Gradient and Bricks component. Using sliders you can alter the generated pattern.
See following lines on how to alter patterns from connected sliders.
Component shortcuts
K1 - K2 -> Kaleidoscope
GR -> Gradient sliders
NO -> Noise Distortion
M1 -> Map script
TR -> Stairs component
Uncheck "Image/Pattern" and set switch "SW-1(4)" to 1 and uncheck "Pattern/Map"
Use following sliders to alter pattern: "K2"
Uncheck "Image/Pattern" and set switch "SW-1(4)" to 1 and check "Pattern/Map"
Use following sliders to alter pattern: "M1", "K2"
Set switch "SW-1(4)" to 2 and uncheck "Pattern/Map"
Use following sliders to alter pattern: "GR", "NO", "TR", "K1", "K2"
Set switch "SW-1(4)" to 2 and check "Pattern/Map"
Use following sliders to alter pattern: "GR", "NO", "TR", "K1", "M1", "K2"
Set switch "SW-1(4)" to 3 and uncheck "Pattern/Map"
Use following sliders to alter pattern: "GR", "NO", "TR", "K2"
Set switch "SW-1(4)" to 3 and check "Pattern/Map"
Use following sliders to alter pattern: "GR", "NO", "TR", "M1", "K2"
Set switch "SW-1(4)" to 4 and uncheck "Pattern/Map"
Use following sliders to alter pattern: "NO", "K1, "K2"
Set switch "SW-1(4)" to 4 and check "Pattern/Map"
Use following sliders to alter pattern: "NO", "K1, "M1", "K2"
All patterns can be altered by "Reflectivity","Reflection Blur" and "Metallic"
Filters: 707
Another of your beautiful Kaleidoscope based filters.
It is always fun for me to change the values a bit and see what new pattern your filters make. smile:D
It is also nice the care how you select so many presets. smile:)
33,833 Registered Users
+20 new in 7 days!
15,390 Topics
