jhantares
Filters: 272
jhantares
Filters: 272
How to use this filter
The source image is connected to a map script component. Up to 7 sliders alter the generated pattern by this component. 6 different patterns are connected to switch "Pattern selector".
See following lines on how to alter these patterns from connected sliders.
Component shortcuts
M1 -> Map script component
PA -> Pavement component
K1-K2 -> Kaleidoscope
BL -> Blend component
ND -> Noise Distortion component
GR -> Gradient component
Set "Pattern selector" to 1, 5
Use following sliders to alter pattern: "M1"
Set "Pattern selector" to 2
Use following sliders to alter pattern: "M1", "K1"
Set "Pattern selector" to 3
Use following sliders to alter pattern: "M1", "K1", "ND"
Set "Pattern selector" to 4
Use following sliders to alter pattern: "M1", "K1", "K2", "PA"
Set "Pattern selector" to 6
Use following sliders to alter pattern: "M1", "K2"
All patterns can be altered by "Reflectivity" and "Metallic" sliders. Switch on "Gradient on/off" to use "GR" and "BL" sliders.
Haras Arch
Hara's Crown
Pretty, pretty rhinestones! (I actually started with pearls.)
jhantares
Filters: 272
great manipulation smile:)
