EAdams
Polygonal Microcosmos by Ramlyn
http://filterforge.com/filters/12658.html
EAdams
I like this filter a lot. Depending on the loaded image, it is worth experimenting with the background color and changing it from the default black.
Filters: 712
Thanks EAdams.
Yes, the blending mode used in the Bomber is "Difference" so, depending on the original and selected colors, the results can be completely different.
If you choose to have only squares in the first Set ( or if you choose the third Set with only the first type of squares ), the result is similar to a tech or greeble surface.
I'm working on two variations of this filter. I'll upload them soon. smile;)
DJI
Official Bologna Tester
Filters: 257
Another fine product from Ramlyn inc. smile:D Here's the original. smile:)
DJI
Filters: 257
And here it is with your default preset. smile:) 1280x960rez. Render and save time around 2 minutes. Not bad. smile:D
Really love this! Very abstract smile:)
Filters: 712
Thanks DJI and Skybase!! smile:D
I'm happy that you like it!
A new one on this same style already uploaded : PolyMicro - Drawings on the Wall
16 unregistered users.
