Filters: 712
Painting in the Night by Ramlyn
http://www.filterforge.com/filters/12642.html
Filters: 712
The filter creates artistic or paint effects on a image.
It sets some basic images, called Sets.
Then some paint effects are applied to the image, obtaining 24 different results, called Paint Sets.
"Paint Sets 1" allows to select one of the first 12 Paint Sets. "Paint Sets 2" allows to select the other 12. "Paint Sets 1/2" let you choose which one you want to use.
I made a second branch of sets, completely identical to the sets previously described, with the only differences that they are used for blending with the first sets and that the final selector ( "Paint Sets AllBlends" ), after the first two choices, contains also some more blending options.
After you selected the Painting Sets, you can use them as they are or pass them through a new row of effects, selectable with "Result Selector". The first 6 choices of this selector are influenced only by "Paint Sets 1/2", while the following 6 are a blend of "Paint Sets 1/2" and "Paiint Sets AllBlends".
DJI
Official Bologna Tester
Filters: 257
Very nice. smile:)
Filters: 712
Thanks DJI! smile;)
You may wonder why "in the Night".
I made this filter in two nights, starting after midnight. Ha! Ha!
Filters: 712
The new version is finally coming! I'm uploading it now.
I completely changed the system to select the Sets.
The original version used 6 Switches to do the selection of the Sets ( Paint Sets 1, Paint Sets 2, etc etc ). It was too complex to use.
Using an original idea of ThreeDee, I programmed 2 custom switches one with 24 and another with 34 inputs, succeeding to reduce the original 6 Switches to only 2.
Filters: 712
I changed the filter description to. This is the new one :
"Paint Set Select" allows to select the Paint Set you want to use.
I made also a second branch of sets, completely identical to the sets previously described, with the only differences that they are used for blending with the first sets and that in the selection ( "Paint Blend Select" ), after the first 24 Sets, there are some more blending options.
After you selected the Painting Sets, you can use them as they are or pass them through a new row of effects, selectable with "Result Selector". The first 6 choices of this selector are influenced only by "Paint Set Select", while the following 6 are a blend of "Paint Set Select" and "Paint Blend Select" Sets.
