| Posted: November 24, 2014 8:57 am | ||
SQUAREPIC 2 - NAEGA JEIL JAL NAGA - ë‚´ê°€ ì œì¼ ìž˜ 나가
The filter is divided in two parts, a Front layer and a Back layer. Front and Back are used in the commands when a command operates only on one of the layers. I will explain how the filter works, dividing the process in some STEPS. Some of the filters STEPS are applied with the same values both to Front and Back layer. Other STEPS have separate selections. STEP 1 ( it applies separately to Front and Back layer ) The first thinkg that the filter does is splitting your picture in blocks. Every block has a single color. The total number of blocks depends on "Color Size". Higher is the value and more will be the blocks composing your picture. STEP 2 ( it applies to both layers ) The following step is applying some patterns to three values : Black Point, Gamma and White Point. This is done through : 1 Pat. Sel ect. The patterns are : 01 Inclined Checkers ( you can customize the quantity and the rotation ) 02 Checkers ( you can customize the quantity ) 03 Round Tiles ( you can customize the mortar, bevel, row shift, quantity, chaos ) 04 Squared Tiles ( you can customize the mortar, bevel, row shift, quantity, chaos ) 05 Slices ( you can customze the number of slices, swirl, rotation, distortion ) 06 Black Hexagons ( you can customize swirl, distortion and size ) 07 Radial Steps ( you can customize the number of steps, distortion, roughness ) 08 Image ( your image without any modification ) 09 Squared Image ( your image split in blocks, as fr om the previous step of the filter ) 10 Minimum ( this can be selected only for Black Point and Gamma ) 10 Maximum ( this can be selected only for White Point ) 11 Maximum ( this can be selected only for Gamma ) 11 Fixed Value ( this can be selected only for Black Point and White Point ) 12 Cells It is then possible, instead to apply a single pattern, to blend two patterns. The first pattern will be the one previously selected with 1 Pat. Select The second pattern can be selected with 2 Pat. Select The double pattern option is activated checking "1 or 2 Pat. ?" Using 1+2 Pat. Mode it is possible to customize the blending mode of the patterns. STEP 3 ( it applies separately to Front and Back layer ) These patterns apply to the picture combined with a secondary source. This source can be kept unchanged in most cases, but sometimes it can be used instead of the patterns to give a more chaotic design or combined with the patterns to spice up the result. Levels Select allows to select among : 1 A greyscale value ( this value can be changed with Levels 1 ) 2 Your image without any modification 3 Cells 4 Cells ( solid fill ) 5 Techno 6 Techno ( solid fill ) 7 Blocks 8 Blocks ( solid fill ) Levels Variat. allovs to change the variation of the option 3, 4, 5, 6, 7, 8. STEP 4 ( it applies separately to Front and Back layer ) The result of these selections is blended with your squared picture. The obtained picture is then passed through the final selection : Set Select. The selections are : 1 Maximum 2 Maximum + Distortion 3 Minimum 4 Minimum + Distortion 5 Maximum + High Pass 6 Maximum + High Pass + Blocks 7 No effect The Front layer is passed through a Threshold, deleting the black areas and it is blended with the Back layer to generate the final Result. As last touch, you can select to add the filter name in Korean. |
| Posted: November 24, 2014 8:58 am | ||
DJI
| Posted: November 24, 2014 10:05 am | ||
DJI
| Posted: November 24, 2014 10:07 am | ||
If you select 11 ( Fixed Value ) for Black Point and White Point, ad a rather neutral option for Gamma ( 08, 09 or 12 ), you can also use Levels Select to make the Front layer looking as a broken wall.
Now I'm working on .....Чашка капучино After Oni Grin with something written in Japanese :
Hok Sam with Thai writings...
And this filter with Korean writings
The next one will have a Russian name. |
| Posted: November 24, 2014 10:35 am | ||
By the way..... Чашка капучино ( Chashka Kapuchino ) is also a song :
ТутÑи - Чашка капучино |
| Posted: November 24, 2014 10:39 am | ||
DJI
| Posted: November 24, 2014 2:27 pm | ||
| Posted: November 25, 2014 12:31 am | ||
2NE1 - ë‚´ê°€ ì œì¼ ìž˜ 나가
ë‚´ê°€ ì œì¼ ìž˜ 나가 means "I'm the best". I chose this name because this was the best among all my SquarePic filters. |
| Posted: December 29, 2014 10:07 am | ||
