DJI
Official Bologna Tester
Filters: 257
Colorful Scrapbook Patterns #3 by DJI
http://www.filterforge.com/filters/12566.html
DJI
Filters: 257
Hi folks. smile:) Here's 5 of the presets from this filter. smile:D
DJI
Filters: 257
Check this out folks. smile:) I made this one with a filter called Wild Orb Perspective by Voldemort. smile:D
DJI
Filters: 257
And this one. smile:D
DJI
Filters: 257
And I did this cube in Paint.net. smile:D
Filters: 712
Nice work DJI.
It fits very well on a sphere. On 3D graphic it could be very good as texture of balls. Also mixing the presets together looks very nice.
The main preset is a bit cartoon-like. It could be a nice background for cartoons and animations.
DJI
Filters: 257
Thanx Ranlyn. smile:) I'm trying to keep it simple for a while. smile:D Here's something i'm toying with now. smile:)
DJI
Filters: 257
Or maybe this? smile:)
DJI
Filters: 257
This maybe? I should put all three in one filter I think. smile:)
DJI, do you know how to control the angle of the spectrum node without using the rotate component? smile:)
DJI
Filters: 257
With the rotate function of the spectrum component which as you know rotates the spectrum 90 degrees. I do as a matter of fact have a checkbox control plugged into the spectrum component of this filter. But if you mean do I know how to rotate the spectrum 360 degrees without the rotate component then the answer is no. smile:|
