DJI
Psychedelic Color Abstraction 01 by Ramlyn
http://www.filterforge.com/filters/12537.html ![]() "Art is quite useless." Oscar Wilde |
| Posted: October 9, 2014 5:21 am | ||
DJI
| Posted: October 9, 2014 5:39 am | ||
Thank you!
The idea started from your "3D Reflective Wavy Abstract Metal", adding color and some other settings. |
| Posted: October 9, 2014 5:58 am | ||
How to use the filter :
The filter structure is divided in 3 main areas : 1. The Art settings. 2. The (A) Color settings. 3. The (B) Color settings. In the filter Controls menu : The first control is used to select no image, color image or black & white image. The following 3 controls define how the colors blends together and with the image, and to select the color pattern ( there are 7 color patterns ). The Art controls modify the filter design in different ways. The following (A) and (B) Color controls are used to modify the 7 color patterns. |
| Posted: October 9, 2014 6:12 am | ||
High Usage Rank!
Thanks to everybody for using this filter! |
| Posted: March 23, 2015 2:03 am | ||
