Sweet texture! One nit picky thing: threshold probably does the same job as the tone curve. Thresholds in FilterForge do process much faster. Definitely recommended for processes that you were doing here.
raabix
Nodist
You are damn right! Honestly I didn't check the filter for best performance, as I was never 100% satisfied with the look of the texture and did not plan to release it to the library (that's why you see so many unconnected nodes in the filter smile:D )
In the end I liked the texture enough and the way the colors blend, that I decided to release it nevertheless.
I always had this texture in mind:
http://cgtextures.com/texview.php?id=...infvnhr112
Anyways, thanks for the hint! I give myself a FF-Wiki treat smile;)
