Filters: 712
Flowers For Algernon Photo Effect by DJI
http://www.filterforge.com/filters/12479.html
Filters: 712
Nice!
I must say that I generally don't like kaleidoscope based filters ( they are too symmetric for my taste. Kaleidoscope also has the trouble that it is not smooth in putting the sections ( pieces ) together, so it is generally possible to see a line separating them ( does anybody know a way to avoid this problem? )).
Instead this filter has a very pleasant look. smile;)
DJI
Official Bologna Tester
Filters: 257
Well thanx Ramlyn,I'll take that as an unqualified rave. smile:)
DJI
Filters: 257
I have an update in the pipline. smile:)
DJI
Filters: 257
Ya know,I can't get this filter just right. smile:( Mabybe somone could take a look under the hood and check it out. The colors off for one thing.
Filters: 712
I think the filter looks very good and doesn't need any change.
If you really ask me "Please, I want to change the filter once again.", then I would suggest only one small particular in the main preset ( the others are ok ).
Look at the upper left corner : there are two white arrows that seem a bit like ....floating over the picture.
In all other presets the color difference between the surrounding area and the "two small arrows" is smoother, so they look more natural and not detached from the rest of the picture.
Instead in the main preset this color/shading difference is much sharper.
It may also depend on the colors of the image, but looking at the bump map the two arrows still have a much lighter color than the rest of the filter.
I think, changing a bit the kaleidoscope setting of the main preset may solve it.
Anyway it is up to you. I don't see it like a problem.
DJI
Filters: 257
Yes,your right.Those things pop up from time to time along the variation control. You just have to keep going back and forth adjusting different controls untill you get an image that looks worth saving. And your right again. I should redo the default preset. smile:) I din't know. It just seems like there is something missing. smile:( Thanx for the comment. smile:D
DJI
Filters: 257
Well folks. I have 2 updates for this filter in the pipline.the next upd ate should be up on monday. But I kept looking at it and decided to work on it some more.So I did and submitted it one last time. Here's the default prese t of the last update. smile:)
DJI
Filters: 257
Yah! The last update,v5.0 is in the pipeline. smile:D
Filters: 712
He! He! Downloaded. smile;)
DJI
Filters: 257
Great. I hope I fixed all the probs. smile:) This is THE last update on this pain in the grass. smile:evil:
64 unregistered users.
