Raindrops and Water Puddle by raabix
http://www.filterforge.com/filters/12473.html
Very nice! I just personally think a lot of these textures accomplish a ton. I'm really thrilled to see some new, highly detailed procedural textures on FilterForge.
xirja
Idididoll Forcabbage
The only thing missing I can see is the meniscus hydro-phobia/philia
Filters: 712
Xirja. Do you have any suggestion about how create the effect of hydro-phobia/philia?
xirja
To adjust the height near where the puddle meets the rock, add or subtract values using a threshold and a curve I suppose. The reflection has a slight distortion at the rim no?
Just giving my observation on what would make it perfectly realistic IMHO. smile:) Of course the larger the scale, the less noticeable the edge bend, so maybe this is some alien world where the raindrops are 10 feet across and we are seeing this from a great height, nothing wrong with that.
raabix
Nodist
the High Pass component is the one you seek to create the desired bevel effect. I did not spend time on this, since this was not the focus to get the borders of the water with the rocks correct, I might add it in a later filter update if I find time.
Filters: 712
I may try to use it in some filter too. smile;)
