jhantares
Filters: 272
Kaleidoscope Generator 6 by jhantares
http://www.filterforge.com/filters/12470.html
jhantares
Filters: 272
How to use this filter
The source image is connected to a map script component "M1". Up to 6 sliders alter the generated pattern by this component. Other patterns are generated by 7 different generators.
See following lines on how to alter these patterns from connected sliders.
Component shortcuts
K1 - K3 -> Kaleidoscope
ND -> Noise Distortion
R1 - R2 -> Rotate
M1 -> Map script
TI -> Tiles
Set "Select pattern (7)" to 1
Use following sliders to alter pattern: "M1", "K3"
Set "Select pattern (7)" to 2
Use following sliders to alter pattern: "M1", "ND", "K3"
Set "Select pattern (7)" to 3
Use following sliders to alter pattern: "M1", "R1", "K3"
Set "Select pattern (7)" to 4
Use following sliders to alter pattern: "M1", "TI", "K1", "K3"
Set "Select pattern (7)" to 5
Use following sliders to alter pattern: "M1", "TI", "K1", "R2", "K2", "K3"
Set "Select pattern (7)" to 6
Use following sliders to alter pattern: "M1", "K1", "ND", "K2", "K3"
Set "Select pattern (7)" to 7
