Water& Blur Frame by voldemort
http://www.filterforge.com/filters/1751.html
Variations #2 and #5 are way cool looking. I tried disconnecting some stuff, and making it a *simple* instead of *surface* filter, but had no luck, it lost that look. I'm not a huge fan of embossing really, and random grainy (refracted) edges only work sometimes. Personally, I'd like to see a 2-D version of this one, with maybe a few more options/features to replace the heigth and frame stuff, and I think you'd have a faster rendering winner. Just an idea, and of course good work as it is. smile:)
voldemort
voldemort
Filters: 649
I just updated this one with the ability to turn off height map
I left reflectivity blur and metalic alone but can change that if needed
the process so you know is simple
place a switch in your filter make one your height map for the other take a profile gradient and set both colors at
127.5
127.5
127.5
flat gray and plug that in as the second option
you effectivly turn off height mapping on it thenits also easy enough to tie in turning off reflectivity metalic and such with the same switch
Ive been adding this feature to all my latest filters since not everyone likes 3d and this way leaves the door open
voldemort,
interesting. i've been using high pass for the height component and as a means to switch that off, i simply set it to 20 on the first slider and 0 on the 2nd, and that effectively turns that off. (i think those were the settings. i may have to amend that when i next look).
for reflectivity and reflect blur and metallic, i simply use int sliders set to 1 to turn off those surface effects.
and on the high pass for height, if you add a blur component between the high pass and the results, you can smooth out that effect for more control and a smoother look but still get the shading.
voldemort
voldemort
Filters: 649
Yeah I do all that to except for controlling the particular aspects as well but if someone wants a simple on and off rather then sliders I find this is the easiest way since it gives them a nice on / off check box the other way is to use levels and a slider to adjust the controls
you just inverse the controls for the white level and max both at 50
and blend it with the result
for controlling height intensity
example
levels----
black 0-50
white 100- 50 so if you take it to maximum it is 50 50 for both thats a nice way of controlling height severity as well
voldemort
voldemort
Filters: 649
I whent ahead and submitted a snippet showing detailed height control
height on / off
reflectivity on /off
reflect blur on / off
metalic on / off
sliders for all if they are on
levels for controlling height
and how to soften the overall height effect
so hopefully this helps folks
Personally since I figured this out I plan on including height controll in all of them that way the option is open because with out the check box the option isnt even available this leaves the door open to the artists choice
57 unregistered users.
