Filters: 712
3D Reflective Deep Blocks Photo Effect by DJI
http://www.filterforge.com/filters/12417.html
Filters: 712
This is another great filter, DJI. smile;)
The way it works on the image is really beautiful and original. There are no other filters that generate similar results.
DJI
Official Bologna Tester
Filters: 257
I had to upd ate the default prese t from the window to the lifesaver cuz the window look bad on the website. smile:)
Filters: 712
The shape and the height of the basic texture is perfect.
And I love this thing :
If you look at the main preset, the up corner on the right for example, you can see how the plant appear frontally and also on the sides of the texture.
Most filters would simply apply the picture to the texture, going frontally OR on the sides, depending on the shape of the texture.
Instead in your filter the plant appears frontally AND on the sides. It is like we had several cameras taking the same picture from different positions and combining them together. Very nice.
DJI
Filters: 257
Well then if you love this image then definitely don't accept the upd ate untill you wright down the placement of the controls so you can remake the prese t or this image will be gone forever. smile:) P.S. Does this happen to you? When I write "Preset" or "Update" the letters are separated and can't be fixed? smile:?:
Filters: 712
OK. Thanks for the hint. smile;)
No, I don't have problems when writing "preset" or "update".
Does it always happen to you when you write these two words in the forum?
DJI
Filters: 257
Yes it does as you can see here and sofar it's just those two words. It just doesn't make any sense. smile:?: upd ate & prese t. See what I mean? That happens on it's own. What the heck is going on? smile:(
Filters: 712
No idea, DJI. It really doesn't make any sense that only those two words don't appear correctly.
