jhantares
Filters: 272
Kaleidoscope Generator 5 by jhantares
http://www.filterforge.com/filters/12404.html
jhantares
Filters: 272
How to use this filter
The source image is connected to "Stone", "Rotate" and "Tiles" component and to input 1 of switch "Select pattern 1(4).
Output of "Stone" component goes to input 2. Output of "Rotate" component goes to input 3. Output of "Tiles" goes to "Pavement" component
and the output goes to input 4 of switch 1.
Output of the switch "Select pattern 1 (4) goes to the map script component "M1". Up to 6 sliders alter the generated pattern by this component.
Output of "M1" goes to "kaleidoscope" component "K1" and "Bricks" component "BR" and "Tiles" component.
Output of "K1" goes to input 1 of switch "Select pattern 2 (4)", output of "Bricks" goes to kaleidoscope "K2" and finaly to input 2, "Bricks" output goes to
is input for cascading "Offset", "Rotate" and "Kaleidoscope 3" components and finally goes to input 3 of switch 2. "Tiles" output goes to "Kaleidoscope 4" input and finally to input 4 of switch 2.
Output of switch 2 goes to "Result" component and shows the resulting altered image.
Every of these components and the assigned sliders alter the resulting pattern. See following lines for details.
Component shortcuts
K1 - K2 -> Kaleidoscope
ST -> Stone
R1 - R2 -> Rotate
M1 -> Map script
PA -> Pavement
BR -> Bricks
OF -> Offset
Set "Select pattern 1 (4)" to 1 and "Select pattern (3)" to 1
Use following sliders to alter pattern: "M1", "K1"
Set "Select pattern 1 (4)" to 2 and "Select pattern (3)" to 1
Use following sliders to alter pattern: "ST", "M1", "K1"
Set "Select pattern 1 (4)" to 3 and "Select pattern (3)" to 1
Use following sliders to alter pattern: "R1", "M1", "K1"
Set "Select pattern 1 (4)" to 4 and "Select pattern (3)" to 1
Use following sliders to alter pattern: "PA", "M1", "K1"
Set "Select pattern 1 (4)" to 1 and "Select pattern (3)" to 2
Use following sliders to alter pattern: "M1", "K1", "BR", "K2"
Set "Select pattern 1 (4)" to 2 and "Select pattern (3)" to 2
Use following sliders to alter pattern: "ST", "M1", "K1", "BR", "K2"
Set "Select pattern 1 (4)" to 3 and "Select pattern (3)" to 2
Use following sliders to alter pattern: "R1", "M1", "K1", "BR", "K2"
Set "Select pattern 1 (4)" to 4 and "Select pattern (3)" to 2
Use following sliders to alter pattern: "PA", "M1", "K1", "BR", "K2"
Set "Select pattern 1 (4)" to 1 and "Select pattern (3)" to 3
Use following sliders to alter pattern: "M1", "K1", "OF", "R2", "K2"
Set "Select pattern 1 (4)" to 2 and "Select pattern (3)" to 3
Use following sliders to alter pattern: "ST", "M1", "K1", "OF", "R2", "K2"
Set "Select pattern 1 (4)" to 3 and "Select pattern (3)" to 3
Use following sliders to alter pattern: "R1", "M1", "K1", "OF", "R2", "K2"
Set "Select pattern 1 (4)" to 4 and "Select pattern (3)" to 3
Use following sliders to alter pattern: "PA", "M1", "K1", "OF", "R2", "K2"
Set "Select pattern 1 (4)" to 1 and "Select pattern (3)" to 4
Set "Select pattern 1 (4)" to 2 and "Select pattern (3)" to 4
Set "Select pattern 1 (4)" to 3 and "Select pattern (3)" to 4
Set "Select pattern 1 (4)" to 4 and "Select pattern (3)" to 4
68 unregistered users.
