| Maxstar | ||
| Posted: July 18, 2014 12:37 pm | ||
softhunterdevil
Nice !
check my filters please |
| Posted: July 18, 2014 2:14 pm | ||
| Maxstar |
Thank you! I hope it helps to bring some sun back to the pictures
| Posted: July 19, 2014 1:09 pm | ||
DJI
I really like this filter allso.I'm a big fan of portrait distortion & any filter that helps me do that is great in my book. Mikhail Gorbachev.>http://www.publicdomainpictures.net/v...ev&large=1
![]() "Art is quite useless." Oscar Wilde |
| Posted: July 21, 2014 7:53 am | ||
| Maxstar |
Thank you DJI!
I can feel the heat of the former Soviet times while looking at your image. An unexpected use I didn't expect when creating it LOL |
| Posted: July 21, 2014 8:12 am | ||
| Maxstar |
A challenge and a little trick... Browsing through the pictures I found this picture (the highest one). It's a sunny day. but there is some blue color cast and the image doesn't feel as sunny as it supposed to. The summer heat filter would be an interesting option. But I couldn't find the right adjustments - it was either not enough or too much too soon (the middle image). And here comes a little trick. In Photoshop I copied the filter layer three times and applied it onto original image three times in different modes and opacities. Like Soft Light - 35%, Screen - 45% and Normal - 35%). Than I masked the skies out to keep them blue. A simple Auto Curve layer was the finishing touch. The last image was the result. Much sunnier.
P.S. Of course I could do it without Summer Heat as well. Choosing white, black and neutral points, adjusting contrast, sharpning, blurring for some glow, applying some yellow filter etc, increasing vibrancy... Still prefer to start with Summer Heat in case I need to add some sun |
| Posted: August 14, 2014 11:24 am | ||
| Posted: August 14, 2014 8:58 pm | ||
| Maxstar |
Thank you for your suggestion, Skybase! I shall try to figure out the way remap works.
| Posted: August 15, 2014 3:55 am | ||
You basically just have to flip values for that part.
So what's going from 0 to 100 should be 100 to 0 |
| Posted: August 15, 2014 4:16 am | ||
| Maxstar |
Thanks again! Figured that out. And learned to use remapping to reverse the values!
| Posted: August 15, 2014 5:47 am | ||
15 unregistered users.
