jhantares
Filters: 272
Kaleidoscope Generator 4 by jhantares
http://www.filterforge.com/filters/12324.html
jhantares
Filters: 272
How to use this filter
The source image is connected to a "Noise Distortion" component and to input 1 of
switch "Select pattern (5). Output of "Noise Distortion" goes to four
other components to alter the pattern. These four component outputs goes to input 2-5 of switch "Select pattern (5).
Output of the switch "Sel ect pattern (5) goes to a map script "M1". Up to 6 sliders alter the generated pattern by this component. Output of "M1" goes to input 1 of "Select pattern (3)" and
to another map component "M2", output goes to input 2 of switch "Select pattern (3)" and kaleidoscope component "K2", goes to input 3 of switch "Select pattern (3)".
Every of these components, generates a different pattern.
Output of "Select pattern (3) goes to kaleidoscope component "K3", output to "rotate" component, output to kaleidoscope component "K4" and finally to "Result" component.
Every of these components, generates a different pattern. See following lines for details in altering the different patterns.
Component shortcuts:
K1 - K4 -> Kaleidoscopes
ND -> Noise Distortion
RO - RO2 -> Rotate
M1 - M2 -> Map script
TI -> Tiles
CH -> Checker
Set "Select pattern (5)" to 1 and "Select pattern (3)" to 1
Source image goes to map script "M1" input. Use map script "M1" sliders to alter pattern.
Set "Select pattern (5)" to 2 and "Select pattern (3)" to 1
Image is altered by Noise Distortion "ND" and kaleidoscope "K1" components. Use "ND", "K1", "M1" to alter pattern.
Set "Select pattern (5)" to 3 and "Select pattern (3)" to 1
Image is altered by Noise Distortion "ND", rotate "RO" and kaleidoscope "K1" components. Use "ND", "RO", "K1", "M1" to alter pattern.
Set "Select pattern (5)" to 4 and "Select pattern (3)" to 1
Image is altered by Noise Distortion "ND", tiles "TI" and kaleidoscope "K1" components. Use "ND", "TI", "K1", "M1" to alter pattern.
Set "Select pattern (5)" to 5 and "Select pattern (3)" to 1
Image is altered by Noise Distortion "ND", checker "CH" and kaleidoscope "K1" components. Use "ND", "TI", "K1", "M1" to alter pattern.
Set "Select pattern (5)" to 1-5 and "Select pattern (3)" to 2
Pattern of map script component "M1" goes to second map script component "M2". Use sliders fr om selected input above and sliders fr om "M2" component.
Set "Select pattern (5)" to 1-5 and "Select pattern (3)" to 3
Pattern of map script component "M1" goes to second map script component "M2", output to kaleidoscope component "K2".
Use sliders fr om selected input above and sliders fr om "M2" and "K2" component.
Every pattern passes the components "K3", "RO2" and "K4". You can alter the resulting pattern by related sliders.
33,864 Registered Users
51 unregistered users.
