TBH-1138
Filters: 53
Multisource Planet Maps by TBH-1138
http://www.filterforge.com/filters/12302.html
TBH-1138
Filters: 53
emenac
Hi, thank you so much for looking into this for me!
I've had a bit of a play with this filter, and I'm getting some promising results. See attached for a texture mapped onto a sphere in Unity3D (with normal + specular map).
I must admit that I don't really understand how the input images are supposed to be used. Are the color and bump sources meant to be matched? (ie. is bump1 supposed to be a bump map for color1?) I'm guessing not, since your example sources don't seem to be matched like that.
Sorry if that's a naive question - I pretty new to all of this.
Any other pointers also appreciated.
Thanks again! smile:)
TBH-1138
Filters: 53
Some of them are (Moon/Mars textures) and some of them aren't (everything else for the most part). Bump 1 will go where Color 1 goes, and so on. They don't have to match, except for moonlike planets where the craters should match up in the diffuse and bump maps.
I've tried making planets in Unity and have a specialized planet shader somewhere that supports atmospheres and diffuse, normal, and emissive textures.
EDIT: Here it is.
Code
  Shader "Planet" {
    Properties {
      _MainTex ("Texture", 2D) = "white" {}
      _BumpMap ("Bumpmap", 2D) = "bump" {}
      _RimColor ("Rim Color", Color) = (0.3,0.5,0.7,0.0)
      _MainColor ("Main Color", Color) = (1,1,1,0.0)
      _RimPower ("Rim Power", Range(0.5,8.0)) = 3.0
     _Emission ("Emission", 2D) = "black" {}
    SubShader {
      Tags { "RenderType" = "Opaque" }
      CGPROGRAM
      #pragma surface surf Lambert
      struct Input {
          float2 uv_MainTex;
          float2 uv_BumpMap;
          float2 uv_Emission;
          float3 viewDir;
      sampler2D _MainTex;
      sampler2D _BumpMap;
      sampler2D _Emission;
      float4 _RimColor;
      float4 _MainColor;
      float _RimPower;
      void surf (Input IN, inout SurfaceOutput o) {
                o.Normal = UnpackNormal (tex2D (_BumpMap, IN.uv_BumpMap));
          half rim = 1.0 - saturate(dot (normalize(IN.viewDir), o.Normal));
          o.Albedo = ((tex2D (_MainTex, IN.uv_MainTex).rgb)*_MainColor)+(_RimColor.rgb * pow (rim, _RimPower));
          o.Emission = (tex2D (_Emission, IN.uv_Emission).rgb);
      ENDCG
    Fallback "Diffuse"
Also it doesn't support specular textures. I thought it did, but it's been a while since I put this shader together.
emenac
Great, thanks again.
31 unregistered users.
