Erik Pedersen
Goggerfett
Geometric Abstract by joBox
http://filterforge.com/filters/12284.html
The Joy is in The Work
Erik Pedersen
Goggerfett
Thank you for this! It's really cool!
WOW!! this is really very good and beautiful!! Like it much. Well done and cool
Eflouret
Filters: 2
Is there any way to make the output seamless? Probably no, but it doesn't hurt to ask.
Filters: 712
This filter contains some non seamless components. There are two Scale and one Rotate. If you delete them, then the seamless checkbox becomes available.
You can try and see if the result is still acceptable for you.
I think that playing with the size and the particle color settings in the two bombers, you can probably obtain similar presets even without using any Scale or Rotate.
emme
Here's a quick modification, not 100% the same but very close.
Geometric Abstract mod 001.ffxml
Eflouret
Filters: 2
Thanks Ramlyn and Emme for your helpful reples. I will try those suggestions.
11 unregistered users.
