| Posted: July 1, 2014 4:49 am | ||||
Very nice kaleidoscopic filter. I tried several pictures, getting great results with all them.
| Posted: July 1, 2014 4:52 am | ||||
Thanks. I like being able to see the "seed" shape first, got this idea from Terrazzo (Xaos Tools, defunct). There are infinite (that's a lot
Also of note, the output of this filter can be used as a seamless tile. I had to turn the option off in the code for technical reasons. Math meets art meets psychedelia. |
| Posted: July 1, 2014 1:56 pm | ||||
Haras Arch
Posts: 226 |
| Posted: November 7, 2015 11:40 am | ||||
No, although at least 2 of the wallpaper groups are in this one. This was my first attempt at tiles, not bad, but disorganized, did not know the whole theory of wallpaper (or that there were 17 types). Also notice that if the image is not square, I did not clean up the excess parts of the image (like your post).
| Posted: November 7, 2015 12:43 pm | ||||
Haras Arch
Posts: 226 |
It actually looked fine in the preview. I was surprised that it added the extra strip at the bottom when it rendered, but of course I can trim it off.
| Posted: November 7, 2015 4:01 pm | ||||
Sigh... I suppose I should fix that. I'll probably consider updating this filter after the 17 Wallpaper Groups.
| Posted: November 7, 2015 4:08 pm | ||||
Since you mentioned it Haras, I have looked at the tiles in Tile-O-Matic and have classified each tile and the wallpaper group it comes fr om.
Tile Type --------- 1 - Wallpaper Group 11 p4mm 2 - Wallpaper Group 11 p4mm 3 - Wallpaper Group 6 p2mm axis rotated 45 degrees 4 - Wallpaper Group 6 p2mm 5 - Wallpaper Group 6 p2mm axis rotated 45 degrees 6 - Wallpaper Group 6 p2mm rectangular 7 - Hybrid: the "cell" is Group 2 p2 (seed rotated 180 degrees), the tiling is Group 6 p2mm. Using an "irregular" seed shape gets into an area known as Heesch tiles, wh ere tiles are modified regular polygons with curves. Maybe if I could draw the curve in FF... Math meets art meets psychedelia. |
| Posted: November 7, 2015 5:05 pm | ||||
The filter has been updated with xirja's speed improvement he suggested while I was working on the wallpaper groups. Tomorrow the excess image bug for non-square images will be fixed.
| Posted: January 15, 2016 3:44 pm | ||||
Like it , well done kaleidoscope effect
i wonder how is going to be fixed this? It will cut the image on the first square part, or will you use the excellent wallpaper groups source image to choose which part will be selected? Thanks to you and cirja for the update |
| Posted: January 17, 2016 2:09 am | ||||
Tomorrow is Monday, not quite yet, but the speed fix is already in... A couple of the file types (3 & 7) return a non-square image if a portrait or landscape image is used. This filter always returns a square result.
| Posted: January 17, 2016 12:32 pm | ||||
Janeway
Amazing!
I used a part of this filter for cuts in my filter. Thank you! |
| Posted: August 15, 2017 9:50 pm | ||||
