jhantares
Filters: 272
Kaleidoscope Generator 1 by jhantares
http://www.filterforge.com/filters/12192.html
jhantares
Filters: 272
How to use this filter
The source image is connected to a map script component which uses 10 formulas to transform it. Up to 6 sliders alter the generated pattern by this component.
The resulting pattern is connected to 5 other component inputs. Every of these components, selectable by "Select pattern", generates a different pattern.
The resulting pattern is connected to a kaleidoscope and at the end to a surface result component.
See following lines for details in altering the different patterns.
Set "Select pattern" to 1
Map script output gets to this input. Use map script sliders to alter pattern.
Set "Select pattern" to 2
Your image is altered by math color components. Use map script sliders and Invert RGB check boxes to alter pattern.
Set "Select pattern" to 3
Rotate component is selected. Use map script sliders and "Rotation, Origin X, Origin Y" sliders to alter pattern.
Set "Select pattern" to 4
Noise distortion component is selected. Use map script sliders and "Angle, Scale, Stretch, Distortion" sliders to alter pattern.
Set "Select pattern" to 5
This input select a new kind of kaleidoscope if formula 10 is select in the map script. Use all 6 sliders of map script component to alter pattern.
Use of formula 1-9 creates nice patterns too, but only sliders "Offset X1,Y1,X2,Y2" are active.
Every pattern passes the kaleidoscope component. You can alter the resulting pattern by sliders:
Kal Offset H, Kal Offset V, Kal Size, Kal Mode and Reflectivity, Reflection Blur, Metallic
Have fun to explore the capabilities of this filter.
37 unregistered users.
