MKBreuer
MKBreuer
Filters: 47
Cat paths by Tomcat
http://www.filterforge.com/filters/12116.html
Just simple, but not simpler. (A.E)
MKBreuer
MKBreuer
Filters: 47
Nice Pattern! smile:)
Tomcat
Thanks! I just queued up an update that gives some depth and lighting to the paths.
Oh sweet nice work! I like the way it just creates the pipes on top and bottom illusion. smile:)
Very nice smile:)
Mardar
Graphics Junkie
Filters: 61
Very nice. Love the update as it improved it a lot. Great first filter. smile;)
Mardar
Graphics Junkie
Filters: 61
Could I make one suggestion on this filter? If you limit the maximum size on your "Grid size" control to 20 instead of 80,it would make it a bit more friendly. If anyone wants a smaller size than that, they can use the "size pixels" at the bottom of the filter to gear it down. It tends to go to the upper numbers when I use the variation button and it is annoying to have to go up and manually dial it back every time. Just a suggestion and it's up to you if you want to change it. I really like this filter and it should go high use if you tweak it just a bit. smile;)
Tomcat
Thanks for the comments, folks.
And that's a good suggestion! I didn't think about how it acts under the randomizer. I'm queuing up a new version, with the size slider limited at 20, and with the "chance" inputs normalized. This means that there'll be no blank spots in the randomized grids any more.
Mardar
Graphics Junkie
Filters: 61
Excellent update Tomcat. Much better visuals on each random click. No more tiny check grids or blanks. Great job. smile;)
softhunterdevil
check my filters
Filters: 11
Wow , very nice
check my filters please
Including bomber roughness:
With a different layering setting:
16 unregistered users.
