I like very much the idea of this filter, and is cool and well done
What I do not know is why you have put most of the presets so dark as you can go to the lighthing tab and rise the Brightness and store this also in the preset, unless you really wanted to show the presets with this very dark color and you like it this way, so if it is this way I can understand it and you do not have to change it, although you could put also one dark version and one lighter version
Filters: 712
Thank you. smile;)
The beginning I made it less dark, but I didn't like the result too much. I even did a test in white and in blue, but it was so so. The 3D effect looked nicer with darker tones, and I decided to upload it without other changes.
Filters: 712
I'm thinking that some preset could look nice with dark green color, because they are similar to plants.
I'll do some test and maybe post a new filter.
Filters: 712
This filter was updated in all its parts, but in the library it still appears with the old presets. I guess there is still some problem in the library.
Filters: 712
Humm... it seems that the problem was solved. Now it appears correctly. Good! smile;)
64 unregistered users.
